A common way that people see safety is it’s something you do on top of your regular work. For example, in addition to repairing a piece of equipment you must lock out and tag out its supply breaker.
But this perception of safety leads to unsafe acts because safety feels like a burden. When you’re pressed for time, you’ll be tempted to take shortcuts and safety will be the primary target. In the example, you might fail to take the time to verify the circuit is actually de-energized because you “know” that’s the right breaker. But what if it’s not? The one next to it is, and you made a simple error. Or suppose a backfeed now exists, and it’s not documented.
A better perception of safety is it’s what you do so that other work can proceed. It’s not that safety is on top of everything else, but that everything else is on top of safety. Safety is your foundation. And as the other work proceeds, safety also becomes the frame to which you attach the component activities.
Mark LamendolaMark Lamendola
