NFPA 70E Tip: Informative Annex Q, Part 5
This Annex is titled “Error Precursors.” The phrase itself gives you a good idea of what it means. Part 5 defines an error precursor as a situation in which the demands of the task and the environment in which it is performed exceed the capabilities of the individual(s) performing it or the limitations of human nature. Obviously, you want to eliminate these kinds of situations wherever possible. To do that, you need to identify such situations.
Q5 groups them into four broad categories:
- Task demands. The task requires mental, physical, or team effort that approach or exceed the limitations of the individual(s) involved. For example, the task is highly detailed and under normal conditions takes 35 to 45 minutes to perform, but (in this instance) it's inside a vessel at 110°F. Solution: Break into subtasks and/or ventilate/cool the inside of the vessel.
- Work environment. The company culture, organizational structure, and/or other workplace issues attenuate individual performance. For example, a micro-managing supervisor undermines a person's confidence. Solution: The worker should tell the supervisor how that style is making him feel and/or the supervisor's manager should assign a different supervisor for this project.
- Individual capabilities. An individual's mental, physical, and/or emotional characteristics don't match the demands of the specific task. For example, Bob, who is 6'4”, is tasked with entering a tiny vessel while Sarah is 5'2” and tasked with installing 4-inch rigid metallic conduit overhead. Solution: Have them switch assignments.
- Human nature. The traits, dispositions, and limitations common to everybody set people up for failure. Example: The same crew is assigned to pull 500 MCM cable for five 12-hour days in a row. Solution: To avoid the injuries that will result from fatigue (probably on the first day), divide the work among multiple crews and have them rotate assignments.
Mark LamendolaMark Lamendola
