You and Bob have a work order to change a light fixture inside an open vessel. Bob says he’ll go down and do the work. He tells you, “Stay topside in case something happens.” You decide to check text messages since you have nothing else to do while standing there. After a few minutes, you peer into the tank. To your horror, Bob is lying motionless on the bottom of the vessel.
Maybe he had a heart attack? Maybe he received a shock? Maybe there’s an accumulation of some gas in the vessel? Should you use your phone to call for help and then go down and get Bob? Can you hold your breath that long?
This is a high pressure situation, but under no circumstances should you enter that vessel. At a refinery in Louisiana, a worker called for help and then entered the vessel to rescue his coworker. When two operators arrived, they called in the situation and then amazingly they entered the vessel. All four people died. The next crew to arrive was equipped with rescue gear (including pullout straps), portable air supplies/masks, and a gas meter.
This situation was preventable. As with the real case, Bob died because of flagrant disregard for OSHA’s confined entry requirements. The real case was initially a tragedy of one death, but the response from three other people sealed their doom as well.
Mark LamendolaMark Lamendola
Related
dreamstime_l_159801249
Dreamstime M 41543526
