Unsafe Conditions in Startup Testing and Commissioning — Part 4
Test technicians may need to operate equipment as part of startup testing, most notably if functional testing is in the program. Usually by the time a new installation is operable, there are dangers if it is operated without coordination and authorization from whoever has control of the equipment.
If the equipment has been turned over to the operators, then they have control of the equipment. Sometimes, however, it’s unclear who has control of the equipment. This will need to be established rather than assumed. It’s usually on a system or subsystem basis, but that is not always the case.
To confirm, contact all parties who may have control of any equipment in the system you are testing. Ensure you can safely operate any controls (including breakers, fuses, and disconnects). You may need to coordinate isolation procedures to proceed (for example, if the process itself is running with actual process chemicals).
If equipment is operating near the test location, determine what hazards that equipment might introduce and how to protect yourself.
Mark LamendolaMark Lamendola
Related
Work Safety Notebook Hard Hat Construction Supplies
Work Safety Guy In Plaid Shirt
