At one time, lockout/tagout training was typically some minimal classroom instruction thing done to “check off the box,” and management in most companies was happy with this. The problem is that such inadequacy got a lot of people hurt or killed while destroying millions of dollars of equipment annually.
In certain environments, such as power-generating stations, and certain fields, such as electrical testing, lockout/tagout training was much more rigorous. It involved instruction, demonstration, and practical application while being monitored by a qualified person. And employees would be trained not just once, but retrained (typically on a schedule).
It should not be amazing to anyone that in these environments, the injury, death, and damage outcomes were far different from those that were laxer.
This better way of training made its way into the 2018 version of NFPA 70E [110.2(B)]. It’s broken down into three phases:
- Initial training. Not only must the employee be trained in the procedures, but the employee must also be trained to understand what their responsibility is in the execution of the procedures.
- Retraining. Three criteria are given for when retraining should take place. While some firms have shorter timeframes for this, NFPA 70E requires it at three-year intervals (at a maximum). If the procedure changes, training in the revised procedure must occur. Of course, any time an employee shows a need to be retrained (e.g., through incorrect execution), retraining must occur.
- Documentation of training. Keep records of who, what, and when — adding “where” doesn’t hurt either.
Mark LamendolaMark Lamendola
Related
lockout tagout
Lockout/Tagout of an electrical panel
