OSHA’s requirements for protecting your eyes and face take up less than two pages of a standard that runs nearly 500 pages.
In those (less than) two pages, you will find:
- Enumerated drawings of eleven types of PPE and what they are called. For example, number 4 is “Spectacles, Metal Frame, with Side Shields” and number 5 is “Spectacles, Plastic Frame, with Side Shields.”
- Table E-1, Applications. This three-column table identifies the operation (e.g., chipping), the hazard (e.g., flying particles), and the recommended PPE (by number, and the preferred PPE are in bold).
- Table E-2, Welding Operations. This two-column table identifies the welding operation and the shade number that should be used. For example, if you’re soldering, you need shade number 2.
- Table E-3, Selecting Laser Safety Glass. This three-column table identifies the intensity, optical density, and attenuation factor.
And of course, there’s the text with the actual regulations. The typical employer of electricians can nearly eliminate any chance of being cited by teaching and enforcing two simple rules:
- You wear safety glasses with side shields at all times on the job unless in a protected area (e.g., lunchroom or office).
- If there is any danger of splash or drops of hazardous chemicals to your face, you wear a face shield.
If you’re an electrician trying to come up with a couple of ways to protect your eyes and face, those same two would do the job.
Adopting these two rules would not protect everyone everywhere from every danger to eye or face, but it would be an excellent start.
Mark LamendolaMark Lamendola
