Solving Two Fall-Related Problems
Use a watermelon to demonstrate what can happen in a fall from a ladder or other high space.
Oct. 19, 2021
We know from OSHA citation records that many companies and employees do not take fall hazards seriously enough. A simple demonstration can change that attitude. Stand on the fourth rung of a step ladder just as you might to work in a ceiling space. Now, drop an average-sized watermelon from waist high. Yes, this is very messy and that is part of why it is effective. Who will clean it up?
Earlier this year, an accomplished mountaineer died when his harness broke and he fell out of it. What went wrong? The harness was so old the materials failed. Any “soft” fall arrest gear (e.g., harnesses and lanyards) should be replaced after 10 years if never used. If used once, that replacement time limit drops to five years.
Set up a replacement schedule for each such item and track its usage. Hard items such as carabiners and buckles should be replaced if dropped from a significant distance or if any malfunction occurs.
