NFPA 70E: Electrical Safety Training Requirements — Part 2
Do you know the retraining requirements for qualified persons?
Sometimes, a qualified person needs additional training or retraining in some aspect of electrical safety. How does a supervisor determine when that is? How does the qualified person determine when that is? NFPA 70E provides five criteria in 110.6(A)(3). If any one of the five is true, then additional training or retraining must be provided to the qualified person in question.
These are:
  1. The employee is not complying with the safety-related work practices. This might indicate a need for training, perhaps previous training was inadequate. But perhaps the employee’s attitude is inadequate. Don’t apply training to fix an attitude problem, and don’t apply formal discipline to fix a training problem. Figure out what the problem is.
  2. You have new techniques, new equipment, procedure changes, etc. Any time there’s a change like this, proceed under the assumption that the training for the old techniques, equipment, procedures, etc., is not going to cut it. Determine what the new safety parameters are and then what training is needed to address them.
  3. The employee performs this task less than once per year. A refresher session will usually suffice.
  4. These particular safety-related work practices are not normally used by this employee during regular job duties. A review with someone who normally does perform them will usually suffice. If no such person is available, then some other sort of review will be necessary.
  5. The employee’s job duties change. The employee will require safety training relevant to the new duties.
Safety training can be a classroom, on the job, or a combination of the two. Assess the risk to the employee to determine the type and extent of the training that should be provided [110.6(A)(4)].
