What Poor Material Management Actually Costs an Electrical Contractor
Key Highlights
- A $200 million-a-year buyer found 40% of people's time went to material management, not installing.
- Slow payments and receivables running 50 to 55 days make cash flow the top cause of contractor failures.
- Three-way matching breaks on construction jobs because deliveries, prices, and quantities all shift mid-job.
- Even contractors running an ERP still patch it with spreadsheets and outside software, opening the door to errors.
- A 4-way match checks every invoice against the PO, sales order, and proof of receipt before payment, not a sample.
Guarantee Electrical, a St. Louis contractor buying $200 million of material a year, went looking for where the money went and found that 40% of their people's time was going to material management. On the margins electrical contractors actually run, in the range of 5 to 6 cents on the dollar, a cost that size doesn't show up as a line item. It shows up as jobs that closed thinner than the estimate said they would, and nobody can say exactly why.
The visible costs of poor material management, the surplus conduit, the returns, the fees for expediting materials, are the small half of the answer. The larger half hides in three places most contractors never total up: labor absorbed by material handling, cash flow stretched by slow approvals, and invoice errors that get discovered after the money is gone. Each one lands differently on the P&L, and the last one is the only one that can't be corrected after the fact.
Where does margin hide?
Material management eats time before it eats anything else. Research across the construction workforce puts 35% of working time into non-productive activities such as hunting for project data and resolving conflicts, roughly 14 hours per person per week, worth an estimated $177.5 billion a year in U.S. labor costs. None of that appears on a job cost report as a material line. On the ground it looks like a foreman on the phone with the office, a purchasing team re-keying the same order into a second system, and an accounts payable clerk chasing a packing slip from three weeks ago.
Guarantee Electrical put a number on it from the inside: "We started paying more attention to how we handle materials when we discovered that 40% of people's time is all about material management. In addition to that, we're buying $200 million of material a year." A contractor doesn't need to be at that scale for the ratio to matter: the same share of a smaller payroll is still money spent on the bureaucracy of buying rather than on installing electrical systems and paid work.
Improve cash flow, visibility creates predictability
The labor drain is chronic, but the cash-flow squeeze is what turns material management from an efficiency subject into a survival subject. Research commissioned by ELECTRI International, the electrical industry's research foundation, found that receivables in construction consistently run 50 to 55 days against standard 30-day payment terms, and names poor cash flow the number-one contributor to construction company failures each year. An electrical contractor is, in practice, financing every job for weeks while supplier invoices come due on their own schedule.
Construction has measured the inbound side of this squeeze to the dollar. Slow and inconsistent payments cost U.S. construction an estimated $299 billion in 2025, in effect a hidden 14% tax on project costs. The outbound side, what contractors lose by paying supplier invoices that don't match what was ordered or delivered, has never been measured at all. There is no published error rate for construction invoices. What exists instead is a month-end pattern: a variance on a closed job, too late to dispute, too small individually to investigate, repeating across hundreds of invoices a month.
The same ELECTRI study points at where control is won or lost. Of 47 managerial strategies rated by contractor finance leaders, one of the highest-scoring was also one of the least glamorous: an invoice checklist ensuring every billing goes out complete. Payment discipline, in both directions, is a process problem. That raises the obvious question: why does the standard process control fail?
Why three-way matching breaks on construction jobs
The control most contractors rely on is three-way matching: compare the purchase order, the receiving record, and the invoice before paying. The logic is sound, and in most industries it works, because most industries take complete deliveries at one warehouse against stable prices. Construction jobs violate those assumptions as a matter of routine.
The failure modes are structural, and they compound:
What the match assumes |
What actually happens on a job |
One PO, one delivery, one invoice |
Partial deliveries spread across weeks, each with its own packing slip, invoiced in fragments |
The PO price is the invoice price |
Price files drift between quote and billing; copper wire and cable alone moved 13.8% in twelve months |
Quantities stay fixed |
Change orders revise quantities mid-stream, and the paperwork trails the work |
Someone reviews every invoice |
At volume, sampling is the only manual option available |
None of those failure modes involves negligence. Material prices averaged a 4.2% increase in 2025, with copper moving far faster, so a PO with pricing agreed at the time and a price invoiced weeks later can genuinely diverge. The documents disagree because they were produced by disconnected systems at different moments in a moving market.
Manual review at that volume looks the way Guarantee Electrical describes it: "We would spot check invoices to make sure that pricing was appropriate. With the amount of material we buy, we can only spot check a very small percentage of that. So it wasn't a good reflection, it wasn't a good check and balance." Spot-checking is the rational response to volume, and it still leaves most invoices unexamined by the one control meant to check them.
There's a deeper reason the match breaks, and it rarely gets named: the purchase runs across two companies. The purchase order lives in the contractor's system. The sales order, the fulfillment record, and the price file live in the distributor's ERP. The two sets of documents are supposed to agree, yet no system on either side can see both. Every discrepancy becomes a phone call, an email thread, or a variance nobody catches, and procurement data never matches the books because the books were reconciled against half the record.
Margin improvement with four-way matching and why it matters
The disconnection is the norm, and it persists even among contractors who have invested in systems. Dodge Construction Network's research on specialty trade contractors found that even firms running an ERP still work around it, with 44% using separate third-party software and 31% using spreadsheets for functions the ERP was meant to cover. Every workaround is another place where a quantity or a price gets re-keyed, and every re-key is another chance for error.
The contractors getting ahead of this are treating the purchase-to-payment chain as one connected workflow between themselves and their distributors. Interstates, an industrial electrical contractor, framed the target plainly: "We look to software like Remarcable to be able to solve manual repetitive tasks like material ordering, like matching an invoice to a purchase order, and effectively managing that transition of information from the field to the distributor to the office."
Connected procurement software closes the gap the spot check can't. When the contractor's purchase order and the distributor's sales order live in the same system, matching stops being a sampling exercise and becomes automatic on every order. Remarcable extends the standard control to a 4-way match, comparing the PO, the supplier's sales order, proof of receipt, and the invoice, so a price that drifted or a quantity that never arrived is flagged before payment rather than surfacing as a variance at close. The checking happens on 100% of invoices, at the only point in the cycle where a discrepancy is still a correction instead of a loss.
The visible costs of poor material management will keep getting attention because they are visible. The margin, for an electrical contractor, is in the other column: the labor hours nobody assigns to material, the cash absorbed by slow approvals, and the invoice errors that become permanent the day the check goes out. Start at that last step. A process change at the point of payment shows up on the next job's P&L, and it is the one part of the chain a contractor can fix without waiting on an owner, a GC, or the market. Procurement software designed for construction can improve margin by finding where margin loss is hidden, improve cash flow as visibility creates predictably, and mitigate a contractor’s financial risk.
