What’s Wrong Here? Hint: Scary Camp Lamp
I spotted this cleat-type lampholder on a recent camping trip. It was installed under the canopy that covered the picnic table at our campsite. There are exposed energized terminals on the side of this lampholder.
Section 410.5 states that lampholders, lamps, luminaires, and portable luminaires “shall have no live parts normally exposed to contact.” The Exception in Sec. 410.5 allows cleat-type lampholders to have exposed terminals where it is located at least 8 ft above the floor. This lampholder is less than 7 ft high and can easily be reached and contacted accidentally. It poses a severe shock hazard.
The other questionable item is the use of flexible cord as a permanent branch circuit wiring method. Section 400.12(1) prohibits using flexible cords or flexible cables as a substitute for fixed wiring of a structure.
Russ LeBlanc
Russ LeBlanc
