Controllers & Relays
22. I-Gard: Sentri Ground-Fault Relay Sentri Ground-Fault Relay The Sentri provides a total solution and coordination with 40 trip levels form 100mA up to 1200 A. This versatile relay can be used in both solidly grounded and resistance grounded ...
Feb. 3, 2012
Sentri Ground-Fault Relay Product Information
23. Littelfuse: PGR-8800 Arch-Flash Relay
Video: PGR-8800 Arch-Flash Relay
24. Schneider Electric: PacDrive 3 Controller
Pluggable interconnects and a quick-connect front-side bus also reduce installation costs. PacDrive 3 Controller Information
25. Schneider Electric: Harmony XB5R Wireless, Battery Free Pushbutton
When the operator pushes the button, mechanical energy is transformed into electrical energy, which sends a one-time radio message to the receiver. The batteryless solution offers permanent availability, benefits the environment, and eliminates costly battery maintenance, re-charging and recycling. The wireless technology helps to achieve greater productivity by providing operators with greater freedom and mobility, allowing them to remotely control machines at a distance of up to 25 meters away in a metal cabinet. Similar to other Harmony products, the wireless, batteryless push button is well-suited for harsh industrial environments where added protection of your people and machines is paramount. Harmony XB5R Wireless, Battery Free Pushbutton Information
26. Schneider Electric: Wiser Energy Management System
