115. Channellock, Inc.: High Leverage Linemen's Pliers
Unlike competing brands, the new High Leverage Linemen’s pliers from Channellock provides greater ease of cut with less force needed to cut through high-tensile-strength fish tape or wire. The entire Line consists of a 7 inch, 8 inch, 9.5 inch, and 10 inch overall sizes so no matter what size job you have, Channellock has the Linemen’s pliers you need.
Videos:
Channellock Provides More Cutting Power to Pros & DIYers with High-Leverage Linemen's Pliers
IMPROVED High Leverage Linemen's Pliers U
116. Milwaukee Tool: 6 in 1 Combo Pliers
In addition to standard pliers applications, the industry’s first 6 in 1 Combination Pliers can be used for reaming pipe, cutting wire, stripping wire, cutting bolts and making loops. The Milwaukee 6 IN 1 Combination Pliers feature a revolutionary dual head design for wire stripping and needle nose functionality. MSRP: $32.99
Important Links:
6 in 1 Combo Pliers Product Page
6 in 1 Combo Pliers Press Release
117. Milwaukee Tool: 10-inch Quick Adjust Reaming Pliers
Designed with the Electrician in mind, the 10 inch Reaming Pliers feature a new-to-world reaming head for easier and more efficient deburring of pipe. No other hand tools on the market integrate a reaming feature into the design of the tool. Users are forced to either carry a separate reaming tool or modify their pliers by exposing the metal at the bottom of the handles MSRP: $22.99
Important Links:
10-inch Quick Adjust Reaming Pliers Product Page
10-inch Quick Adjust Reaming Pliers Press Release
118. QuickTreX: Wire Surgeon Wire and Kevlar Cutting Scissors
Ultra precision Solingen serrated stainless steel blades for clean and precise cutting of wire, Kevlar, braiding, etc. holds up under extreme use. Great multi-use tool for electricians and structured network cabling installers. Incorporates an easy-to-use wire stripper and a splice and terminal crimper that can be used for copper wires from 26 to 18 AWG. The MSRP for the Wire Surgeon Wire & Kevlar Scissors is $33.62. Wire Surgeon Wire and Kevlar Cutting Scissors Product Information
