Test Equipment
106. Agilent  Technologies Inc.:  M8190A Arbitrary Waveform Generator From  low-observable systems to high-density comms, testing is more realistic with  precision arbitrary waveform generation. Now you can take reality to the  extreme: An Agilent AWG ...
Feb. 3, 2012
From low-observable systems to high-density comms, testing is more realistic with precision arbitrary waveform generation. Now you can take reality to the extreme: An Agilent AWG is the source of greater fidelity, delivering high resolution and wide bandwidth – simultaneously. This unique combination lets you create signal scenarios that push your design to the limit and bring new insight to your analysis. Get bits and bandwidth – and enhance your reality. M8190A Arbitrary Waveform Generator Product Information
107. Milwaukee Tool: Fluorescent Lighting Tester
The Milwaukee 2210-20 Fluorescent Lighting Tester is a new to world tool that tests fluorescent lighting fixtures and cuts troubleshooting time in half. The Fluorescent Lighting Tester delivers complete Lamp, Ballast and Pin testing. Test Lamps before or after installing, and test without dismantling the fixtures. MSRP: $199
Important Links:
Fluorescent Lighting Tester Product Information
Fluorescent Lighting Tester Press Release
