Boxes & Enclosures
1. Cooper B-Line: Rapid Ring Self Adjusting Prefab Ring Installing in as little as 15 seconds, the Cooper B-Line Rapid Ring Self-Adjusting Pre-Fab Ring automatically adjusts to drywall thicknesses of up to 2 inch.   By reducing installation time to ...
Installing in as little as 15 seconds, the Cooper B-Line Rapid Ring Self-Adjusting Pre-Fab Ring automatically adjusts to drywall thicknesses of up to 2 inch. By reducing installation time to just 4-steps, the Rapid Ring system can help win tight bids. Rapid Ring Self Adjusting Prefab Ring Product Information
Cooper Crouse-Hinds: PowerGrip MSB Bracketed Boxes
Designed for the fastest, most secure and tool-free installation of outlet boxes on steel studs! The PowerGrip family is the most complete offering of bracketed boxes in the industry and includes a superior far side support. Boxes include shallow and deep 4 inch and 4 11/16 inch for use with conduit, armored/metal clad cable and non-metallic sheathed cable. PowerGrip MSB Bracketed Product Information
IPEX USA LLC: NEXO ICF Box
The INEXO ICF Box is the only electrical box designed and approved for post concrete-pour ICF construction. The INEXO box is equipped with four unique locking teeth that engage the ICF (Insulated Concrete Form) block to create a secure connection; therefore, the electrician does not have to mount the box within the poured concrete or drill into the cured concrete with a special drill; thus, making the INEXO ICF box a time and labor savings product. Insulated Concrete Forms, or ICF's, resemble large LEGO foam blocks made of expanded polystyrene (EPS) and are filled with reinforced concrete to produce a structurally-sound wall with a typical minimum insulation value of R50. NEXO ICF Box Product Information
Stahlin: Polystar Family of Enclosures
PolyStar Enclosure: A durable NEMA 4X polycarbonate enclosure with 7 standard sizes: 6x6x4 8x6x4, 10x8x4, 12x10x6, 14x12x6, 16x14x8 and 18x16x10 with opaque and transparent covers. Features Stahlin's revolutionary sub–panel and side mounting solutions with superior flame protection rating of UL94 -5VA. Rated Type 3R,4,4X,12, IEC 66 - UL/cUL approved. Polystar Enclosures Product Information
Thomas & Betts: Steel City 68-HP Non-Metallic Floor Box
Thomas & Betts’ Steel City 68-HP Non-Metallic Floor Box is a six-inch round box with the capacity for three standard devices under a single, round cover, instead of a large, rectangular box with multiple covers. Voltage dividers allow any combination of power, data, and audio-visual devices to be installed. Steel City 68-HP Non-Metallic Floor Box Product Information
