Nonmetallic cable splice and tap
The NM Splice and Tap technology provides a fast and reliable way to connect 12 AWG and 14 AWG circuits using nonmetallic (NM) cable. It eliminates the need for junction boxes, covers, fittings, and wire nuts. It’s approved for use in a variety of applications, including residential branch circuits, manufactured housing, and pre-fabricated building structures. When adding new circuits in residential applications, NM connectors eliminate both the need to cut into the existing wiring and the extra junction boxes and associated hardware required for the tap connection.
AMP Netconnect, a division of Tyco Electronics
For more information, visit http://energy.tycoelectronics.com.
