Product News
Underground switchgear
The Vista UDS/System VI Switchgear family now features a 2,000A continuous rated main bus with a short-circuit rating of 25kA symmetrical in voltage ratings through 38kV. The switchgear can be furnished with as many as five 600A to 900A load-interrupter switches and/or fault-interrupters sealed in an SF6-insulated, welded steel tank. Four-layer copper bus, dual air bushings, and a taller, wider tank are required to attain the 2,000A continuous rating.
S&C Electric
Circle 201
Corrugated nylon conduit and tubing
FPAS corrugated nylon conduit and tubing is a wire protection product for pumps, motors, HVAC systems, machine tools, electrical housing, and cabinetry. The interior of the tubing is smooth, which allows wires to easily pass through, and a damage-resistant corrugated exterior allows the tubing to withstand abrasions and lubricating fluids while it fits around the tightest bends and corners without distortion. The product is available in nominal sizes ranging from ¼ in. to 2 in. in diameter.
Heyco Products
Circle 207
Convertible tablet PC
The screen on the LifeBook T4000 convertible tablet PC has a 180° viewing angle so users can work with the keyboard or a pen for data input and management. A modular bay gives users the flexibility to choose between a multi-format DVD writer, second battery, or weight saver option. The PC has advanced security features to deter unauthorized users and enable secure authentication. When both batteries are installed, the system has a battery life of as many as 8.5 hrs.
Fujitsu
Circle 206
