Product Spotlight
Focus on Instruments and Test Equipment Industrial digital multimeter The DM-860-C is a general-purpose, 500,000-count digital multimeter that offers a measurement range of up to 1,000VAC and 1,000VDC, up to 10A AC and DC, and up to 1,832F. It's especially designed for in-plant and MRO applications.Greenlee TextronCircle 302 Power quality analyzer The 43B power quality analyzer displays voltage and
The DM-860-C is a general-purpose, 500,000-count digital multimeter that offers a measurement range of up to 1,000VAC and 1,000VDC, up to 10A AC and DC, and up to 1,832°F. It's especially designed for in-plant and MRO applications.
Greenlee Textron
Circle 302
The 43B power quality analyzer displays voltage and current waveforms, calculates power parameters, and captures voltage sags, transients, and inrush current. It can measure 3-phase power in balanced systems using a set of voltage probes and a current clamp.
Fluke
Circle 301
EMF detector
The EMF-200A hand-held EMF detector features high-resolution measurement and is designed to measure field radiation at different bandwidths. The LCD reads 0.1 mG to 199.9 mG over an ELF range of 30 Hz to 400 Hz.
A.W. Sperry
Circle 306
Six-phase power analyzer
The WT1600 6-phase power analyzer offers up to six input elements, Ethernet capability, and 12 MB of internal memory. It also features a 2.1 GB hard drive, SCSI interface, floppy disk drive, and 6.4-in. TFT color LCD with VGA monitor output.
Yokogawa
Circle 305
Overhead line and meter base recorders
The Ramcorder product line includes the OH1600, which installs on overhead distribution lines and records current and temperature measurements. The RCMB model installs at the meter socket and records current and voltage measurements.
HD Electric
Circle 303
Cat. 7 cable testers
These cable testers are designed to certify cabling systems for high-bandwidth networks. This month, the company plans to unveil the testers — which will include a Cat. 7 LAN tester — along with accessories and upgrade packages.
IDEAL Industries
Circle 300
Location system accessory for Palm devices
The Handheld Dataviewer (HDV) enables users to view target position, depth, and electronic confirmation data on a Palm V device. The HDV can receive data from the company's other products via a wireless link, reducing the need to carry a PDL-4 receiver.
Radiodetection
Circle 304
