Eliminating Repairs
A plant saves a lot of money and lost production by reducing how long a given repair takes. Trimming repair times is well worth the effort. But what if you could eliminate the repair in the first place? By this, we don't mean early detection and intervention, though that is also worthwhile.
To eliminate repairs, you must determine the cause of the failure that made a repair necessary. A large percentage of failures are due to human error during maintenance activities. So, start by analyzing maintenance activities for opportunities for elimination or frequency reduction. Modifying an activity is also good; for example, install color-coded test ports to eliminate getting into cabinets to take voltage measurements.
Operator abuse, even if unintended, is another source of failure. How can that be designed out? For example, an operator performs too many restarts in a given time. Installing a control device that limits restarts to X starts per Y minutes will prevent that, or a thermal-based solution can be used.
Installing controls for overspeed, overtemperature, over-vibration, over-pressure, and other harmful conditions can also prevent equipment failure.
Sometimes equipment is used beyond its design parameters, causing failure. What design change could accommodate that use?
Mark LamendolaMark Lamendola
Related
