What Level of Repair is Acceptable?
If an electrician changes out a large component in a white cabinet and accidentally scratches the paint, how should that be addressed?
- Leave the scratch alone; it probably won’t rust.
- Cover it with a typing correction solution.
- Cover it with caulking.
- Repaint the entire cabinet wall so it looks like new.
Any of these might be acceptable (even not repairing), depending upon how critical the appearance is and how much you want to spend to get there. Is the scratch inside, where it is unlikely to be seen? Or is it on the outside? Is the cabinet along the walkway where VIPs might see it, or is it on the backside of an equipment skid where almost nobody will see it? Would painting in place expose operators to paint solvents when a little caulk would not expose them to any toxins?
Coming up with a general guideline and communicating the “why” to repair techs can avoid both costly over-repair and sloppy under-repair (which is also costly).
Mark LamendolaMark Lamendola
Related
Plant Workers Taking A Break Dreamstime Xxl 86406443
Repair Word On Book Page Dreamstime Xxl 151699280
