Don't Reward Sloppy Repairs
Bradley was a maintenance electrician at a high-volume factory. For some reason, Zach, a production supervisor, didn’t like Bradley. Zach said Bradley’s repairs “took too long.” Zach complained to Bradley’s boss whenever Bradley responded to a downtime call. Zach often pointed out how quickly Don handled a similar repair.
Eager to win Zach’s approval, some of the other maintenance electricians began to copy Don’s methods. The plant engineer soon noticed a sharp spike in downtime.
Come to find out, Don achieved his speed by fixing only what obviously was broken. He never bothered to investigate why it had broken. Thus, if a motor failed due to voltage imbalance, Don would not know that. Bradley, on the other hand, would note the problem on the repair ticket and write a work request to solve the imbalance.
Unlike Bradley, Don did not replace hardware in torqued connections and retorque them. Going back through the infrared scans and correlating loose connections with Don’s repair tickets confirmed this.
The lesson here: Don’t confuse sloppiness with efficiency.
Mark LamendolaMark Lamendola
Related
Dreamstime M 187445107
Dreamstime M 66888837
