Hiring, Developing, and Retaining the Best People
Seven characteristics good maintenance people share
If you have worked in maintenance for a few years, you know the best maintenance people share certain characteristics. These traits usually are not spelled out in a resumé or revealed in an interview.
Look at your best maintenance people, and you should see these seven attributes:
  1. Has a sense of urgency.
  2. Not afraid of hard work.
  3. Neat and methodical.
  4. Focuses on what matters; gets to the crux quickly.
  5. Shows respect and courtesy toward others.
  6. Professional appearance.
  7. Listens without interrupting.
In the hiring process, you can ask the interviewee to give examples of how they exhibit the first four characteristics (the last three will be obvious). The answers to the first four will also show if the person understands the difference between having a sense of urgency and rushing around.
Use coaching, culture, and leadership to help people develop strength in areas where they are weak, and you will improve retention by improving their job satisfaction and self-esteem.
