Batching PM/PdM Per Component Instead of Asset
Generally, equipment does not all go into service at the same time. Preventive maintenance (PM) and predictive maintenance (PdM) schedules for a given asset normally begin with its first day of operation. If you have a large spread (and you probably do), you may have an opportunity to significantly reduce maintenance costs while uncovering problems sooner.
Suppose the plant has 12 major production lines. All have similar components that can be checked in some way without requiring downtime. Examples include motors, motor drives, terminations, gages and other display units, and sensors.
Rather than task individual maintenance techs to assemble the same test equipment and related tools 12 separate times, put certain maintenance tasks for all 12 lines on the same PM. The PM data still gets recorded on a per asset basis, but the work gets done by one person or crew on a single trip from the shop.
If you identify 10 such tasks, you multiply the savings by 10. You also have maintenance eyes on the equipment 10 times more frequently.
Mark LamendolaMark Lamendola
Related
Dreamstime M 12926340
Prioritizing Repairs 1 2 3
