Code Quiz
When installing loudspeakers in fire resistant-rated partitions, walls, and ceilings, the loudspeakers shall be ________.
Feb. 16, 2012
Fill in the blank with the correct answer.
  1. approved
  2. listed for the purpose
  3. installed in an enclosure or recess that maintains the fire resistance rating
  4. listed for the purpose or installed in an enclosure or recess that maintains the fire resistance rating
Answer: D
As noted in 640.25 of the 2011 NEC, when installing loudspeakers in fire resistance-rated partitions, walls, and ceilings, the loudspeakers shall be listed for the purpose or installed in an enclosure or recess, that maintains the fire resistance rating.
