True or False? When calculating the volume required for a box, a single volume allowance of one conductor (based on the largest equipment grounding conductor) is required for all EGCs in the box.
See the answer below.
Answer: False
Explanation: A change in the 2020 NEC to Sec. 314.16(B)(5) now requires a single allowance for up to four equipment grounding conductors (EGCs) and an additional ¼ volume allowance for each conductor exceeding four.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
dreamstime_xxl_321335940
wooden quiz blocks with pen and calculator
