Question: Does the service equipment of a 480/277V service installed outdoors require illumination?
See answer below.
Answer: Yes, if the service equipment is for an assembly occupancy.
Explanation: Section 518.6 of the 2020 NEC requires illumination of service equipment installed outdoors for assembly occupancies. Section 110.26(D) already requires illumination for all indoor services rated 1,000V or less.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
A white question mark drawn on a blackboard
code quiz
