Code Quiz: Power Needs in a Pool Equipment Room
Test your NEC knowledge.
Based on the 2020 NEC.
Question: Does the NEC require a general-purpose receptacle to be installed in pool equipment rooms?
 See answer below.
Answer: Yes
Explanation: The 2020 NEC added Sec. 680.22(A)(5) to require at least one GFCI-protected 15A or 20A, 125V receptacle. Any additional receptacles would also require GCFI protection. This was added to provide safety during maintenance by eliminating the need for an extension cord to another receptacle in a location that may not have GFCI protection.
John Lupacchino
Senior Design Engineer
