Code Quiz: Location of Equipment Near Swimming Pools
Based on the 2020 NEC.
Question: How far must electrical equipment be located from a swimming pool?
See answer below.
Answer: 5 ft
Explanation: Section 680.22(E) of the 2020 NEC requires equipment that exceeds the low voltage contact limit to be located at least 5 ft from the inside wall of a pool unless separated by a permanent barrier.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
Dreamstime M 26526712
Dreamstime M 207865151
