Based on the 2020 NEC.
Question: Can a second utility service be used as an emergency power source?
See answer below.
Answer: Yes
Explanation: As per Sec. 700.12(F), a separate service is permitted as an emergency power source if it is approved by the authority having jurisdiction (AHJ). Separate service conductors including laterals and drops are required. The service conductors must be installed sufficiently remote both electrically and physically to minimize the possibility of simultaneous interruption.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
Niro Design I Stock Getty Images Plus
Ecmweb 24602 Quiz On Wooden Blocks Gustavofrazao Istock Getty Images Plus 1 5e148dcba4355
