Code Quiz: Replacement Options for Two-Wire Non-Grounding Receptacles
Based on the 2020 NEC.
Question: What are the options for replacing an existing 15A, 120V two-wire non-grounding receptacle when there is no available equipment ground in the box?
See answer below.
Answer:
- Replace it with another two-wire non-grounding receptacle
- Replace it with a GFCI receptacle marked "No Equipment Ground." No equipment grounding conductors are permitted to connect to receptacles served from this GFCI receptacle.
- Replace it with a grounding-type receptacle when supplied through a GFCI. These shall be marked "GFCI Protected" and No Equipment Ground." No equipment ground wire is permitted to be connected between the receptacles.
Explanation: See Sec. 406.4(D)(2) in the 2020 NEC.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
