Code Quiz: Dwelling Load Calculations
Based on the 2026 NEC.
Question: Does the floor area of an attached garage need to be included in the area used to calculate the load for a dwelling unit?
See answer below.
Answer: Yes
Reference: Section 120.5(C)
Explanation: The 2026 NEC clarifies that "detached garages" are excluded from the floor area calculation. Attached garages are required to be counted as they are often used to expand dwelling unit living space.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
