Based on the 2026 NEC.
Question: What is the largest size PVC conduit permitted to be installed per NEC requirements?
See answer below.
Answer: 6 in. trade size
Reference: Section 352.20(B)
Explanation: 6 in. trade size is the largest size permitted to be installed, however there is an exception to Sec. 352.20(B) that permits larger sizes if the conditions listed are met. PVC is commercially available up to 8 in.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
Related
dreamstime_xxl_223093248
