Lighting connector
The Pro Series low-voltage lighting connector features a snap-around gel-filled connector that cuts wire with an inside knife edge, which the company says eliminates wire stripping and improves safety. Moisture-resistant, the connector is designed for use with 10- and 12-gauge landscape lighting connections.
Kichler Lighting
For more information, visit www.landscapelighting.com.
