Equipment cleaner
Contact Cleaner 2000 VC is an alternative precision cleaner designed to remove contaminants from electronic equipment.
Contact Cleaner 2000 VC is an alternative precision cleaner designed to remove contaminants from electronic equipment. An alternative to HCFC 141b-based cleaners when sensitive plastics are not a concern, the company says the product has no flash point, is compliant in all 50 states, contains no Class I or Class II ozone depleting chemicals, and is non-flammable. In addition, it is NSF K2 registered for use in meat and poultry plants. Available in a 16-oz aerosol can, the product is not recommended for use on Noryl or polycarbonate-type plastics.
CRC Industries
For more information, visit www.crcindustries.com/ei.
