Focus on Construction Equipment
Track trencher attachment
Designed for use in wind energy applications, the CL80 cable layer attachment sorts, configures, and feeds three cables, one ground wire, one conduit with fiber-optic cable, and one tracer tape in a specified configuration into the trench — all in one pass. A series of rollers then guides the cables over the machine and feeds them into a cable box, where they are sorted in the appropriate configuration.
Vermeer
Circle 304
Sonde housing
This sonde housing features a ¾-in.-thick access door for added protection of electronics. According to the company, the product's housing is as much as 33% thicker than comparable units and features a larger body diameter for greater wear resistance and durability. In addition, the housing incorporates a 7-hole Vermeer pattern that is compatible with UTI pilot bits, including UTI Gold Series bits or Vermeer pilot bits. Custom adapters allow the housing to be used with all makes and models of drill rigs.
Underground Tools
Circle 305
Excavators
The E32 and E35 M-Series of excavators fall into the 3-ton to 4-ton weight class. According to the company, the machine's enhanced hydraulic system increases the arm breakout force by 10% over previous models. A conventional Tail Swing excavator, the E32 features a re-engineered house that reduces the overhang by 45% compared to those of comparable size. The E35 is a Zero Tail Swing excavator designed for work on space-constrained job sites. Both models use an X-frame undercarriage that features increased ground clearance and enables greater shedding of debris for cleanup.
Bobcat
Circle 306
Reel supports
The Reel Buck supports utility reels up to 36 in. wide and up to 50 in. in diameter. In addition, the support unit can handle a load capacity of up to 1,200 lb. Designed for outdoor use and treated to resist weather corrosion, the product's frame is constructed of 2-weld, rectangular steel members. According to the company, the product's design allows it to act as a reel transporter as well as a reel stand.
General Machine Products
Circle 307
