Product News 1, May 2010
Line-interactive UPS The Agility Series includes five high-density line-interactive UPSs ranging from 750kVA to 3,000kVA in a 2U chassis platform. Designed for servers, large peripherals, storage systems, and other networking equipment, the UPSs feature 2-tier buck and boost technology. In addition, all five models feature integrated communication line protection to safeguard phone or network connections.
The Agility Series includes five high-density line-interactive UPSs ranging from 750kVA to 3,000kVA in a 2U chassis platform. Designed for servers, large peripherals, storage systems, and other networking equipment, the UPSs feature 2-tier buck and boost technology. In addition, all five models feature integrated communication line protection to safeguard phone or network connections. Other features include scalable batteries, dual bank load shedding, and inputs, including RS232, USB, RJ45 Ethernet, and an RJ11 remote emergency power-off port.
Chloride
Circle 150
UPS
The Liebert PSI uninterruptible power supply (UPS) system gives users 5 min. of battery backup at full load as well as the ability to remotely monitor and shut down connect equipment via Liebert Multlink software. The UPS is rack/tower convertible and available in 1,000VA, 1,500VA, 2,200VA, and 3,000VA in 120V and 230V models. In addition, all models feature eight battery-backed outlets, transient voltage surge suppression, and an RJ-45 port for data line surge protection.
Emerson Network Power
Circle 151
freeproductinfo.net/ecm
400V UPS
Designed to provide back-up power and scalable battery run times, the model 9390 and model 9395 UPSs are now offered in 400V UL-listed configurations, delivering clean power directly to the IT rack at 230V without the need for a stand-alone power distribution unit. According to the company, the 400V configuration requires no changes to IT devices and power loads.
Eaton
Circle XXX
Lightning protectors
The AL-CAT5SJW compact weather-resistant lightning surge protector is designed for use with 10/100 Base-T Cat. 5 Ethernet networks and is Power-over-Ethernet (PoE) compatible. Providing protection to data lines as well as PoE power feed lines, product features include 802.3af modes A and B PoE compatibility, reverse polarity PoE compatibility, and shielded RJ45 jacks. In addition, it supports the use of shielded Cat. 5 cable.
L-com
Circle XXX
