Mounting bracket
The LVK1 non-metallic, low-voltage mounting bracket is suitable for Class 2 wiring installations in existing walls with PVC electrical non-metallic tubing (ENT)
The LVK1 non-metallic, low-voltage mounting bracket is suitable for Class 2 wiring installations in existing walls with PVC electrical non-metallic tubing (ENT). Featuring a knockout for ½-in. or ¾-in. tubing that can be used as a template to cut the hole, the bracket adjusts to fit wallboard from ¼-in. to 1-in. Tightening the product’s mounting wing screws pulls the bracket securely against the wall.
Arlington
For more information, visit www.aifittings.com.
