Where does your department store corrosive chemicals? If you store them in lockers designated and designed for the purpose and those lockers are in a well-ventilated location, that’s great. If you store them in an electrical room, you need to find a different location. Not only are corrosives often flammable, they are always corrosive and vapors escaping from the containers will corrode the electrical gear.
Regardless of the amount of corrosive you are using:
- Follow the ventilation recommendations on the material data sheets (MDS) and product container label. You might plan to use an insignificant amount, but you could accidentally spill the container or just end up using more than you had planned to.
- Use all the personal protective equipment (PPE) recommended on the MDS and product container label. Don’t try to “save time” by confusing the amount of solvent with the strength of the solvent. Skipping that charcoal canister respirator could mean permanent lung damage, and skipping that face shield could leave you disfigured for life.
- Treat it with the care that safety demands.
Mark LamendolaMark Lamendola
Related
chemicals in lab
chemicals in lab
