Protecting Other People
Have you stopped to think about how something you do might make others less safe?
Unsafe acts are usually thought of in the context of harming oneself or being harmed by the unsafe acts of others.
Have you stopped to think about how something you do might make others less safe? For example, you are terminating several bundles of cable in a set of panels. That means stripping many wires and ejecting many tubular bits of insulation all over the floor. This creates a condition where someone else’s shoe may suddenly slide across a bunch of these insulation bits. Do you need to stop periodically to pick up insulation bits? No, you have other options.
For example, you can eject into a wastebasket; even if you occasionally miss the basket, the hazard might be eliminated. Even better, you can rope off the area. This will also protect people from other things you might do (e.g., drop a tool while above them on a ladder).
Roping off an area is one of the best things you can do to protect others. Think of it as a first resort, not a last one.
Related
41543526 © Pleprakaymas | Dreamstime.com
Dreamstime M 41543526
