Tips for Longer, Safer Power Tool Battery Life
Power tools and their batteries are rugged instruments designed to perform tough jobs, but they still require care to maintain safe, optimum performance. There are steps users can take to extend tool and battery life and help keep power tools operating at peak performance for a longer life cycle. The Power Tool Institute has compiled a list of these best practices.
Safe handling
Start by reading the manufacturer’s instruction manual – and only use original manufacturer’s system components of tool, battery, and charger. Do not impact or damage a battery (for example, do not use it as a hammer); use it solely for the defined purpose as specified by the manufacturer. If a battery has received a sharp blow, been dropped, or is damaged, discontinue use.
Regularly inspect batteries for signs of damage, such as crushing, cuts, or punctures. Be mindful of abnormal battery behavior, such as failure to fully charge or hold a charge, longer-than-usual charging times, noticeable drop in performance, liquid leakage from the battery, or melted plastic anywhere on the pack. These are indications of an internal problem.
Never modify, disassemble, or tamper with the battery because the performance can become unpredictable and dangerous. As a general practice, it is best to unplug battery chargers and remove battery packs from them when not in use.
Safe storage
Do not store batteries on their chargers. Always use and store the battery within the temperature limits stated by the manufacturer. Do not store in a closed location where sunlight may cause elevated temperatures, such as near a window or inside a vehicle. Do not store or transport the battery in a container with loose metal objects, such as coins, keys, or nails, which may contact the terminals.
Safe response to overheating
Though batteries and chargers are safe to use when operated properly, in rare instances, a battery may overheat. If the battery is exhibiting signs of overheating (flames, smoke, smoldering, or melting), immediate action is required. If connected to a charger when exhibiting signs of overheating, always unplug the charger first. After unplugging the battery charger, pour plenty of water on the battery, and then submerge the battery (including any attached tool or charger – do not directly touch/disconnect the battery) in a sturdy container filled with water. When transferring the battery, avoid direct contact with the battery (use a long-handled shovel), and use appropriate personal protective equipment to protect face, hands, and body, since there is a risk that overheated batteries may vent, explode, or emit flame.
If the battery is exhibiting flames, continue using enough water until the flame is extinguished. Then submerge the battery (including any attached tool or charger) in a sturdy container filled with water. If water is not available, dirt, sand, or a conventional ABC extinguisher may be used in an attempt to smother and cool the battery until water is available.
Keep the battery submerged, in a well-ventilated location, for at least 24 hr and at least 15 ft away from any combustible items. Contact the manufacturer for guidance on proper disposal.
For more information about extending the life of power tools and their batteries, visit https://www.powertoolinstitute.com/.
