What’s Wrong Here? Hint: Communication Breakdown
Do you know what's wrong with this installation?
The weight of all these communication circuits is tearing the siding off the side of the building at the point of attachment. I’m not sure if the customer owns these wires, or if the utility company does, but in any case, it makes for a great photo opportunity and a Code discussion. Section 800.44(D) requires overhead communication cables and CATV coaxial cables between buildings or structures, including the supports or attachment fixtures, to have sufficient strength to withstand the loads to which they are subjected. In this case, the attachment fixture was secured only to the siding rather than to a structural member of the building resulting in the siding pulling away from the building. If this installation is not repaired soon, serious damage could result to the building as well as these communication cables. As it is right now, rain, snow,  and ice can enter the building through the gaping hole.
Russ LeBlanc
Russ LeBlanc
