What’s Wrong Here? Hint: I Spy a Service Disconnect
Think you know what's wrong with this installation?
Hint: I spy a service disconnect
It may take some close examination, but if you really, really try, you may be able to find the hidden service disconnect in this Photo. Here’s another hint. The handle for the disconnect is under the blue baseball cap! In fact, that baseball cap is hanging on the handle! The property maintenance manager has certainly made himself at home in this space.
Perhaps he’s made himself a little too comfortable. His desk and belongings are completely blocking the service disconnect. The service disconnect must be located so as to be readily accessible per Sec. 230.70(A)(1). The definition of “readily accessible” in Art. 100 means equipment is “capable of being reached quickly” without needing to climb over, under, or remove obstacles, or resort to portable ladders, and so forth. The desk and all the other items here are clearly obstacles blocking access to this disconnecting means. In the event of an emergency, finding this disconnect could be as time-consuming as finding an object in an “I spy” game.
Russ LeBlanc
Russ LeBlanc
