What's Wrong Here? Hint: Removing or Installing Meters Could be Really Scary
How well do you know the Code? Think you can spot violations the original installer either ignored or couldn’t identify? Here's your chance to moonlight as an electrical inspector and second-guess someone else's work from the safety of your living room or office. Can you identify the specific Code violation(s) in this photo? Note: Submitted comments must include specific references from the 2023 NEC.
Hint: Removing or installing meters could be really scary.
Tell Them What They've Won…
Using the 2023 NEC, correctly identify the Code violation(s) in this month's photo — in 200 words or less — and you could win a $25 Amazon gift card. E-mail your response, including your name and mailing address, to [email protected], and Russ will select one winner (excluding manufacturers and prior winners) at random from the correct submissions. Note that submissions without an address will not be eligible to win.
August Winner
Our winner this month was Darryl Jones II, an EC&M reader from Goose Creek, S.C. He knew the service-entrance (SE) cable was not properly supported.
Section 230.51(A) requires SE cables to be supported with straps or some other approved means within 12 in. of the weatherhead and at intervals no greater than 30 in. With the top portion of the SE cable flopping around, I would also argue it does not comply with Sec. 230.54(D). SE cables must be securely held in place. The position of the weatherhead is a concern too. It may not comply with Sec. 230.54(G) because it could allow rain to enter and seep down into the cable jacket and make its way all the way down the inside of the cable to the equipment terminals where it terminates. I have seen many corroded terminals caused by this very thing.
Russ LeBlancRuss LeBlanc
