Answer:
I found this receptacle in the equipment room of a hotel. I wondered if corrosion in the block wall had disintegrated the original device box or if the original installer never put one in. This installation wouldn’t qualify for a so-called "boxless" installation, so I have to believe a box was never included in the original installation.
As per 300.15 of the 2005 NEC, “A box shall be installed at each outlet and switch point for concealed knob-and-tube wiring.
“Fittings and connectors shall be used only with the specific wiring methods for which they are designed and listed.
“Where the wiring method is conduit, tubing, Type AC cable, Type MC cable, Type MI cable, nonmetallic-sheathed cable, or other cables, a box or conduit body shall be installed at each conductor splice point, outlet point, switch point, junction point, termination point, or pull point, unless otherwise permitted in 300.15(A) through (M).”
> Try Another Quiz
Joe Tedesco
Tedesco served the industry in many roles during his career. He was a director, senior electrical code instructor for National Technology Transfer, Inc. and American Trainco, Inc.. He was also a codes, standards and seminar specialist for the International Association of Electrical Inspectors and an electrical field service specialist for the National Fire Protection Association in Quincy, Mass. He ran his own business as an NEC consultant and is a Massachusetts licensed master electrician and journeyman electrician and certified electrical inspector (one and two family 2A; General 2B, and Plan Review, 2C). Tedesco also wrote articles for CEE News and EC&M (Code Violations Illustrated and What's Wrong Here?) for more than 15 years and helped launched the Moving Violations video series.
