Repairs: Fast or Thorough?
One expert says to fix things quickly. Another says to fix them thoroughly. Which one is correct? That depends.
It’s best to figure that out before the need for a particular repair arises. Make the decision and record it in the computerized maintenance management system (CMMS) or in the repair procedure for that equipment.
Factors to consider:
- Extent of damage. If a 100-hp motor fails, you know to determine the cause before replacing it. But suppose a 2A fuse for a controller blew. Do you need to conduct extensive troubleshooting to determine why? Yes, if there is other damage. If there’s not other damage, the answer depends on the next factor.
- Failure history. How often has this failure occurred lately?
- Cost trade-offs/risks. How much does another downtime incident cost versus the cost of a thorough repair, and what’s the risk?
- Safety, environmental, or legal issues. No question, the repair must be thorough if a repeat failure could reduce safety, harm the environment, prevent a legally required standby from running, etc.
Be sure to add conditionals. An example: If production risks not meeting an order deadline, we fix fast but tag the equipment for thorough repair once the deadline risk has passed.
Mark LamendolaMark Lamendola
Related
tips and tricks
industrial engineer checking system
