Train More Than the Technical
Look at the typical training matrix, and every skill is a technical one. Now consider two maintenance electricians, Larry and Bob.
Larry has completed every item on the matrix, while Bob has completed only half of the items. Which person is the better maintenance electrician?
The correct answer is, “I don’t have enough information to determine that.”
When Larry changes a gasket, he leaves a fair amount of the old material on the metal. When asked about this, he says, “It’s good enough.” Bob takes the time to get the surface clean to ensure a reliable seal. When Bob replaces a motor, he uses a torque wrench to tighten the mounting bolts to the specified torque; Bob tightens by feel. Larry never quite cleans up behind himself, Bob always does.
Now can you determine which person is the better maintenance tech? The difference is attitude. Don’t leave this to chance. Define the key attitudes you want your maintenance electricians to have, and train for those explicitly.
Mark LamendolaMark Lamendola
Related
Dreamstime M 172194067
