Conducting a Maintenance Harm Assessment
People make mistakes, but the effects can be minimized.
Various studies conducted over several decades have shown that a significant number of failures result from maintenance errors. That is a sobering thought for an organization dedicated to preventing failure.
Sometimes, it’s a matter of competence; the person performing a particular task has not been properly trained to do so. This is a failure of management, and it should be systematically corrected.
Other times, it’s just human error. People make mistakes. This isn’t anybody’s fault, but the effects can be minimized. Oversimplifying the work actually will increase mistakes. Instead, look at processes and procedures to see where errors are likely to occur. Then ask the maintenance techs how these methods might be improved.
How do you know which maintenance actions are causing breakdowns? One approach is to have repair techs make observations during a repair. Facilitate this with a simple checklist titled “Possible Maintenance Errors.” Have a few checkboxes and list items such as;
  • Dirt in equipment;
  • Misalignment;
  • Connection too loose/too tight;
  • Wrong fuse; and
  • Other.
Update this list as things evolve.
