Fix Frustration Factors — Part 5
Maintenance workers tend to be proud people. Proud not in the sense of vanity, but in the sense of doing quality work that makes a difference.
Suppose the conveyor on Line 3 is prone to jamming, and this causes the drive motor to overheat. Every few days, a maintenance tech responds to a jam-related trouble call. The maintenance techs have suggested several fixes, such as a motor torque switch to flash a light so operators know to clear the jam. Yet, no fix is ever implemented. The same work gets done repeatedly, sending the message that maintenance work has no value.
On another line, there is a repair that would be made easier with a jig that one of the maintenance techs made a prototype of. The jig would not only make the repair more accurate, but it would also prevent the accidental scratching of the enclosure. You send the prototype to a shop to make a proper jig, sending a clear and positive message to maintenance techs.
Mark LamendolaMark Lamendola
Related
Frustrated Engineer At Construction Site Benjawan Sittidech Dreamstime
Fustrated And Stressed Construction Worker Dreamstime Xxl 156879314
