Fix Frustration Factors — Part 4
At a three-shift Tennessee factory, one production line experienced a 3-hr unplanned shutdown several times per year. The culprit was always a large gear drive that had spun a bearing.
For the repair, an electrician isolated the energy sources and disconnected the motor. Three mechanics removed the gear drive and replaced several bearings. This part took two hours because extensive disassembly was required.
The electrical maintenance supervisor observed the repair and asked the plant engineer why they do not just keep a spare gearbox assembly in the stockroom. The plant engineer said he’d already requested that and been turned down.
The electrical maintenance supervisor noticed ground rods around the equipment, which led to noticing that bonding jumpers were missing. The electrician said he would put in a work request to create a good EGC, but the plant manager would not approve purchasing the materials.
At this plant, management specialized in “saving money at great cost.” Not only did they unnecessarily experience large revenue losses, but they also lost good mechanics and electricians due to sheer frustration.
Mark LamendolaMark Lamendola
Related
Frustrated Engineer At Construction Site Benjawan Sittidech Dreamstime
Under Pressure Dreamstime Xl 116278005
