Fix Frustration Factors — Part 1
One way to attract and retain qualified maintenance people is to identify and correct the problems that frustrate them, especially in high-pressure situations, such as repairing equipment during unscheduled downtime.
As a bonus, fixing these factors will (in most cases) reduce the time it takes to perform the repair while reducing the likelihood of error and increasing the likelihood of a truly complete repair.
Imagine the following scenario: Jim responds to a downtime call. The machine in question is needed for an important order that must ship today. It turns out that a motor failed, but no worries because there’s a spare in the stockroom. Jim and Bill work on that hot machine, sweating profusely, to get the old motor out. When they succeed, they are soaking wet and covered in grime.
Jim gives the new motor’s shaft a quick turn. At the grinding sound, both their hearts sink. This motor was not stored properly and cannot be used. This is one example of the kinds of frustrations that drive good employees away. Have you proactively fixed common frustration factors?
Mark LamendolaMark Lamendola
Related
Fustrated And Stressed Construction Worker Dreamstime Xxl 156879314
Under Pressure Dreamstime Xl 116278005
