Overlooked Ways to Reduce Downtime
Battery-powered personal headlamps and specialized tool caddies can help accomplish this.
A bad unplanned shutdown can throw the maintenance schedule off. What often happens is preventive maintenance (PM) gets delayed, skipped, or trimmed to save time. The time isn’t saved, however; it’s borrowed, and the interest rate is high. As more equipment breaks down from this “solution,” more PMs are delayed, skipped, or trimmed. Worse yet, repair jobs are rushed instead of being done thoroughly, and this likely results in more breakdowns.
You may think the trick is to break the cycle as early as possible, and that makes sense. But what if you can shrink every part of the cycle? Accomplish this by observing how people do PMs and repairs, and then find ways to improve speed, accuracy, and ergonomics. Something as simple as a kneeling pad can make a big difference (have you ever knelt on a cement floor for an hour?).
Battery-powered personal headlamps, specialized tool caddies, and specialized fixtures that serve as “third hands” are just three solutions.
Related
